Water Spurting out of Steam Vents.
Athana
Athana Member Posts: 105
edited May 2024 in Strictly Steam
Not about mine but a friend has one pipe steam cast iron radiator system and some of her radiators are spurting out water.She has put cut in half plastic bottles over vents so that they will not keep wetting wall and has a bucket to receive the water that spurts down dripping to protect the floor.
What is the usual reason for this.Thank you
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,622
    Need to know the history. When did it start? Were there any changes made to the system? What is the water level in the boiler? There was either too much water in the boiler and/or system. Or there is water getting trapped by any one of a number of potential causes. Are the radiator shut off valves fully open?
    Also the pressure setting on the pressure control device.
    old_diy_guy
    ethicalpaul Member Posts: 8,933
    Does the water level shown in the gauge glass drop during the heating cycle?
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,363
    President
    HeatingHelp.com
