Sensi Lite with one pipe steam?
Anyone used a Sensi Lite thermostat with a 1-pipe steam system? I currently have a CT300 2-wire (no common C) and want to replace it with a Sensi Lite
Any comments suggestions or experiences would be appreciated
Thanks!
    ethicalpaul Posts: 9,092
    edited May 2024
    They say it doesn't need a common wire, but then it has this footnote:
    Systems that require a common wire include heat-only and cool-only systems
    So I think you'll need a common wire to use this, which is no big deal, but why do you want to use this thermostat instead of a standard programmable?
  • samdobbs
    samdobbs Posts: 9
    Thanks for pointing that out — now I should check if my CT300 actually has a common wire (it is heat only or at least wired to only control my boiler)
    The sensi-lite is very appealing for its (1) wifi and (2) t-stat simplicity with all functions app controlled. I dont see any other simple tstat with wifi?
    Jamie Hall Posts: 27,989
    Two comments. First off, define "simple". There are quite a number of what I would regard as simple thermostats with varying degrees of wifi control — Ecobee is a good one, and the ubiquiour Nest is great for forced air (and pretty horrible for much else). They all require a common wire, because wifi is a hungry transmitter.
    The other question however is… why do you need anything more complex and a battery powered programmable? Steam systems do not work well with multiple setbacks or temperature changes per day — a setback (modest) at night is OK, but fiddling the thermostat during the day only burns more oil or gas or electricity.
    Mad Dog_2
  • samdobbs
    samdobbs Posts: 9
    Thank you. My notion of "simple" is just on-off i.e. no two-stage, no day/night/weekday programming, etc. I wanted wifi only to check and set and turn off when traveling. Also, I dont really understand offsets and setbacks although I assume they influence short cycling. I was attracted to sensi-lite also coz they explicitly mention boilers.
    I guess I'm also misunderstanding common wire which I thought was really the analog of neutral or ground. And that the sensi-lite got its 3v wifi power from aa batteries.
    I assumed my ct300 simply closed the circuit between R-W to turn on i.e. a circuit like 24vpos —> boiler switch pole1 —> R —> tstat —> W —> boiler switch pole 2 —> 24vneg prolly too simplistic/naive
    I'll check out the ecobee, and welcome any other recs, thank you!
