OT Int'l Electrical Adapter three prong vs two prong
D107
This is for US to China for things like charging cell phones, camera batteries etc. We have one three prong (in and out) and 2 two prong (in and out). We want to have 4. Wondering for these simple devices is there any need to get three prong units? Should I ditch the two prong units and go with the 3?
China uses continental European plugs with slim round pins. For grounding appliances there's a contact at the edge of the housing. Most of the appliances a traveler would use do not have a ground connection, so two pins are enough.
China does not use the large format British plugs or the angled ones used I believe in South Africa.—
Bburd2 -
Thanks. My wife has experienced basically the type 'i' outlets there, see below. There are two other kinds but the 'i' is what she needs. These are also apparently good for Australia. Much different than the British or Indian outlets. Good to know two prong are OK for camera batteries and Iphones.
Nothing wrong with type A which I remember were standard here in fifties.
Too bad that voltage and frequency can differ. I wonder what the history is?0 -
I only saw types C and F in China. This was in Guangzhou and Beijing about 15 years ago. It's interesting that they don't have a national standard according to that chart.
Bburd0 -
Why reinventing the wheel? For protectionism?bburd said:It's interesting that they don't have a national standard according to that chart.
There are already too many of them.
See https://www.iec.ch/world-plugs0 -
It's not just the configuration of the prongs you need to worry about -- although I would (and did, some years back) simply get one of the many international travel kits which have an assortment that covers pretty much anything.
You also need to consider voltage and frequency. Some devices -- chargers for phones, for instance, in most cases -- don't care. Some care very much, to the point of destroying the widget if used on the wrong frequency or voltage (not to mention burning your hotel room down).Br. Jamie, osb
Agreed. These days what gets charged via local outlet is cellphone, camera battery, laptop, and, via the laptop USB, a water pic. For things like hair driers, hopefully travelers' hotels will have their own hooked up, unless traveler has a unit that has variable voltage or brings along a voltage converter. Those with sleep apnea machines should double-check voltage/Hz. My major concern was using an ungrounded two prong adapter, but our devices would seem not to need a ground. China's electrical current seems to be 220V, 50 Hz.
For all those interested, this is the website for the Int'l Electrictrotechnical Commission:
https://www.iec.ch/homepage0 -
When personal computers became available the story was that they needed a ground for neutral. Technically ground, return; and neutral are distinct. Are foreign 220 volt systems two live out of phase like here or is one wire a return?0
There are no safe assumptions.jumper said:Are foreign....
The majority of domestic(*) power is grounded on one side to divert lightning strikes, but -part- of Brazil is wired leg-to-leg delta, both power wires over 100V away from local ground.
(*)Get out of the house into industrial work and many other systems can be found.)
I know it wasn't smart, but we never thought twice of breaking off the grounding prong to fit a tool in to a Two prong outlet..No time for safety...ha ha... Haven't done that in a long time. Mad Dog
I'm assuming China has GFCI built into the entire electrical system in every building so every outlet is protected. If that's the case two prongs is fine even if the device wasn't plastic. It's still possible to shock you but it'll be limited and not lethal.D107 said:This is for US to China for things like charging cell phones, camera batteries etc. We have one three prong (in and out) and 2 two prong (in and out). We want to have 4. Wondering for these simple devices is there any need to get three prong units? Should I ditch the two prong units and go with the 3?
If the device are all plastic then it's not going to matter anyway.
In my country you could see any type of distribution system including corner-grounded power system.jumper said:Are foreign 220 volt systems two live out of phase like here or is one wire a return?
My house is 3 X 240V without neutral.
see: https://en.wikipedia.org/wiki/Earthing_system
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
