Boiler crackling/popping - HELP
natalie12
natalie12 Member Posts: 2
edited March 2024 in THE MAIN WALL
I have an old boiler (thought to be about 20 years old) planning on getting replaced within next few weeks so don't want to spend much to repair.
Has began making Kettling noises, and we have no hot water/heating and pressure has dropped low. Is it safe to just turn off and leave off til we have it replaced or is this an urgent thing that could be dangerous if left and needs to be looked at as soon as possible?
Looking for advice please, thanks in advance.
neilc
  • Ironman
    Ironman Member Posts: 7,942
    Is it leaking water?
    Shut off both the water fill valve and the gas should not be a problem. Shut off the electricity too.
    Bob Boan
  • natalie12
    We have turned it off at the mains for now.
    It seems to be leaking a very small amount.
    Is it safe to just leave off til we can get replaced (looking now to do this asap) or do we need to get someone out to look at this more urgently? (I'm clueless about boilers)
    Jamie Hall Member Posts: 27,699
    Safe enough to leave it turned off. Except you may be chilly...
    Turn off any water feed to it, too -- in case a leak turns into a fountain.
