Thermostat change, now furnace won't work
lhalstead
lhalstead Member Posts: 2
Hello, We attempted to change the thermostat to a Nest, learned it was not compatible. Put old thermostat back, appears to be working, clicks as if heating, but thermostat will not kick on.
  • lhalstead
    correction....furnace will not kick on.
    ethicalpaul Member Posts: 8,930
    How many wires are going into the thermostat? Are you sure they are hooked up the same as before? (taking a before picture is very very helpful but it might be too late)
    HVACNUT Member Posts: 7,526
    This is a hot air furnace, or a water boiler?
    Post pics.
    pecmsg Member Posts: 7,281
    Did you disconnect the power at the furnace / boiler?
