Circulate air from radiant heat.
I have a garage that has radiant heat and an addition that doesn't. Is it possible to heat the addition by circulating air from the heated garage?
    By radiant heat do you mean a heated floor? Of course you can circulate the air -- if they are immediately adjacent, just a fan... the only question would be is there enough heating capacity in the garage to heat the addition as well.
    pecmsg Member Posts: 7,191
    Air moving unless heated feels cool. Get a modene heater.
    hot_rod
    HVACNUT Member Posts: 7,507
    Like an open loft over the garage or a closed space?
  • Dave Carpentier
    Dave Carpentier Member Posts: 640
    You would need to circulate the air, like a supply air duct and a return duct.
    Possible hazard would be CO gases from garage blowing in to that non-garage room.
    Possible hazard of a fire in the garage quickly blowing smoke in to or even an easy path for the flames to get to that other space. I had to put 3/4" drywall on the ceiling and adjoining wall of my garage to help slow down fire intrusion into the main dwelling.
