weird behavior this season
delcrossv
delcrossv Member Posts: 2,204
edited January 2024 in Strictly Steam
Last couple of years I referbed my MIL's old Weil Mclain one pipe system, new mains vents etc. ran great. 3oz pressure , like a clock.
This year, did the usual flush and add some 8 way, and the pressure is really high, and the water level is all over the place. Mainly the boiler is filling. Replaced the electric valve and the manual fill so no new water there.
2 questions: I think one of the tenants and their rad valves partially closed and I'm trapping condensate (I'll check that this weekend) Plausible?
Second, what's with the pressure? Do Big Mouths require maintenance? System is running close to 1psi! :#
Vent setup:
  • KC_Jones
    KC_Jones Member Posts: 5,939
    Yes it is. If it is closed enough, but still slightly open, it can allow steam flow, and the surface tension can cause water to back up. I learned this during my own learning curve with steam. Usually you can hear this at the radiator when the system is running. Will sound like steam percolating through the trapped water.
    2014 Weil Mclain EG-40
    How much 8 way did you put in? Enough is fine -- but much more can cause a surging.
  • delcrossv
    Not much, water is pink, not purple like for a cleaning.
  • delcrossv
    edited January 2024
    The high pressure is worrysome. Can someone post the process for "timing the burner" to get cu ft to btus? Just want to verify the burner gas pressure isn't too high- regulator is a 60 year old Maxtrol.
    Nevermind, found it! :)
    Any other reasons the pressure should be so high?
    EBEBRATT-Ed Member Posts: 20,482
    Bad pressure control, pigtail plugged , plugged vents etc.
  • delcrossv
    edited January 2024
    Plugged vents after 2 seasons? I'll pull them and take a look. Pigtail and pressuretrol seem okay as the gauges are reading. Do Big Mouths fail closed?
    ethicalpaul Member Posts: 8,933
    What do you mean "mainly the boiler is filling"?
  • delcrossv
    edited January 2024
    over a few cycles the boiler has more water in it than it started with. I do have a suspicion on that (see above) as it can't come from anywhere else
    I'm a little confused about your suspicion...the only place water can come into a boiler is via its connection to the water supply...is it still filling after you disabled the auto-feeder?
  • pedmec
    pedmec Member Posts: 1,462
    did you remove the chemical from the boiler? Water chemistry could be playing games with your water line. What kind of water feeder are you using?
  • delcrossv
    Not enough 8 way to make a difference based on prior years
  • delcrossv
    edited January 2024
    Condensate is getting trapped in one or more partly closed radiators, level drops during cycle, autofeed puts some in, wash, rinse, repeat.
    I'm not there during the week to monitor so the autofeeder stays on for now.
    FYI it's a McDonnel Miller 61, so no delay like with a Hydrolevel. And before anyone asks , I checked it- clean and not sticking.
  • BobC
    BobC Member Posts: 5,570
    This is how to clock a gas meter, make sure other gas appliances are off before doing this so that boiler is the appliamce your measuring.
    3PSI gauge
    delcrossv
  • Neild5
    Neild5 Member Posts: 203
    Any vent can fail closed if a rust particle gets in it and blocks the vent.  I have had 3 failures on my 10, the original seal melted, I replaced with hi temperature silicone Owings and haven't had any problems.
    delcrossvethicalpaul
  • delcrossv
    edited January 2024
    OK, went down there yesterday and opened all the radiators in all the apartments. about half were closed because it was about 80+ degrees in every apartment except my MIL's who, in a fit of frugality decided to turn off most of her radiators. Unfortunately, the building thermostat is in HER apartment. :#
    The results were just what one would expect.
    After opening all the emitters, I took about 20 gallons of excess condensate out of the system.
    Sheesh, I neglected the Oma factor. 🙄🙄🙄
    CLamb
