Prestige Solo 110 boiler. Is there a way to switch modulation off and on?
kcopp, and Daveinscranton
A jacket inside is fine for me but not for my wife. Even with low outside temps in the 30's, all 5 zones are warm, but never hot, and oftentimes it doesn't feel warm nside. For example, the fan's temperature sensor in the kickspace heater under a kitchen cabinet doesn't get hot enough to turn on automatically, but I can turn it on manually. The outside temperature sensor setting is 0°F for the boiler to fire at maximum firing temperature, and when outside temps get frigid, the circulating zone water does get hot. I manually setback my (dumb) thermostats to 65°F each night.
I like the dpdt/pot solution, thank you.Life is a river, changing at the blink of an eye.0 -
That's a viable solution, but I was thinking of short duration 'on demand' heating, when my modulating boiler would have decreased efficiency for only a short period of time.Life is a river, changing at the blink of an eye.0
Originally, I was thinking of a attaching a small (outside) peltier plate to the ambient temperature sensor, but the dpdt idea sounds cheaper, and doesn't necessitate a ladder.
I just have to figure the resistance value of that ambient sensor at 0°F. And I don't want to have to use an amp meter on a ladder at or around 0°!!! Life is a river, changing at the blink of an eye.0 -
If you are trying to mount your switch some distance from your boiler, like next to your thermostat, you can get it down to 3 conductors and spdt if you need to. Assuming you have 3 spare conductors available.
Pretty easy to graph the curve of the ODR vs temp. Room temp, refrigerator temp, outside temperature, freezer temperature. Gives you four temps to plot vs ohms. If you want to get fancy, you can add appropriate fixed resistance to your linear taper potentiometer so that it falls neatly into to factory ODR extremes. Not necessary. Can add a $10 timer and a button on the wall to add “hit once and forget “ for X number of minutes of high heat.Depends on how we manage to amuse ourselves, I think. If you do any of this, write it down, and why. It will be confusing in a few years, without notes.1 -
If you either change out the snap disk to a lower rating or put an adjustable aquastat on the kickspace heater, you can get it to turn the fan on at a lower setting.
Another option would be to utilize the CH2 call for heat on the boiler and set it up with a more aggressive outdoor reset (or none at all). You could then use a double-throw/double pole switch (a 4-way light switch would work) to toggle between the CH1 and CH2. If the boiler is controlling the system circ, it would be a bit more complicated..."If you can't explain it simply, you don't understand it well enough"
Albert Einstein2 -
Zman, I've put a different lower temp snap disk on that kickspace heater's 1/4" pipe years ago and rewired it for manual operation. Thanks for your suggestion.Life is a river, changing at the blink of an eye.0
You can turn off your boiler.
Disconnect your ODR.
Measure the resistance. Do this at different temperatures over a few days. Plot the curve.
This assumes it is a royal pain to get to the ODR. (Ladder).
You may be able to look up the ODR parameters. The manufacturer may publish it.
My boiler tells you the outside temperature on the boiler information flat screen display. It interpolates for you. My ODR is a negative correlation device. Resistance goes down as temp goes up.
Fun project. Make it do what you want.
1 -
Bob Rohr, The kickspace fan has a high and low speed setting.Life is a river, changing at the blink of an eye.0
if you have the newer style prestige control (CTRLMAX) then I think Zmans suggestion makes the most sense. you could wire up a separate thermostat to CH2 and make it fire at a setpoint temperature, turn it off when you want to go back to standard heating curve0
Nice! Thank you! I always overthink, with little common sense. I can get a current temp reading on the Solo 110. The temp sensor is high near the peak ridge under an overhang for shelter. Needs an extension ladder.Daveinscranton said:You can turn off your boiler.
Fun project. Make it do what you want.Life is a river, changing at the blink of an eye.0 -
The boiler is older. I did a DIY replacement of my 40 yr. old forced air furnace in 2008. That was an expensive learning curve. Bought all the components (with a couple home improvement loans, gradually over months time. I wasn't aware that some water was present from Triangle Tube pressure testing. I had to drag my Smart 60 indirect fired water 'heater' back up the basement stairs and roll it around on the grass to flush out a lot of rust in the water jacket. My pex is gray, not white from the residual iron oxide.GGross said:if you have the newer style prestige control (CTRLMAX) then I think Zmans suggestion makes the most sense. you could wire up a separate thermostat to CH2 and make it fire at a setpoint temperature, turn it off when you want to go back to standard heating curve
I like the CH2 suggestion and different curve if the rest of the system supports it. (Not familiar with your boiler)
You could use a wind up electro mechanical timer. Instead of a thermostat. They are cheap. Available in 15 minute (max), 30 minute (max) etc flavors. Wind it up to X number of minutes and done. Shuts itself off.Now you are down to 2 extra wires with something that shuts itself off and can’t be inadvertently left on.1 -
Thanks for all the suggestions Daveinscranton. I put a couple of push-button timers in for my two domestic hot water recirculating pumps. The one to the second floor wastes a little energy because the height creates a natural convection. I could prevent that by closing the ball valve, but that would be a PITA. Since then I've had a pipe dream of a ladder logic circuit opening an electronic valve before energizing the recirc pump, then turning the recirc pump off before closing the electronic valve. It'll never happen.Daveinscranton said:I like the CH2 suggestion and different curve if the rest of the system supports it. (Not familiar with your boiler)
You could use a wind up electro mechanical timer. Instead of a thermostat. They are cheap. Available in 15 minute (max), 30 minute (max) etc flavors. Wind it up to X number of minutes and done. Shuts itself off.Now you are down to 2 extra wires with something that shuts itself off and can’t be inadvertently left on.Life is a river, changing at the blink of an eye.0 -
Solved: Tech at Triangle Tube said that my outdoor temperature sensor, Triangle Tube model PSSENS01, has a resistance of 12K ohm at 78°F, and 89.93K ohm at 0°F. No sensor or a broken one would simulate an open circuit with infinite resistance. I'll just put in an on/off switch to break the circuit when I wand the boiler to fire at it's maximum set point. My modulating boiler will be temporarily inefficient at those times. Thanks for all your help pitching in!Life is a river, changing at the blink of an eye.2
Good idea, especially for this 73 yr. old noggin of mine.
Finally got my inline SPST wall switch (no hot, neutral, or ground wires) spliced into one wire of the outside temperature sensor yesterday evening. With a closed circuit to my outdoor temperature sensor, and the outside temperature being 32°F, the boiler's modulation curve reached 142° supply water. At that same outside temperature, with temperature sensor's circuit open, the supply temperature topped out a 182°F, which is the normal maximum set point for when the outside temperature is 0°F. My wife and are enjoying a toasty new year's morning. After a much quicker time reaching a comfortable 72°, I (the non-automatic boiler modulator) have switched the outdoor sensor back online.Life is a river, changing at the blink of an eye.0
I setback mine to 67°F but have a window cracked open in the bedroom. That room hovers around 60 but the rest of the house is warm in the AM.
Removed0
