Issue with conquest 80
ArgaTheRexouium
Member Posts: 1
in Gas Heating
Hi i have conquest 80 furnace whenever the unit is turned on even with the thermostat wiring disconnected after a minute or so the draft inducer powers on and 10 to 30 seconds later the main blower starts and both remain running until you kill power to the furnace
On the control pcb the ok and power leds are in continuously
The flame led is off to start then the draft inducer then after a delay it starts slow flashing for about 6 seconds when it then starts fast flashing with the indoor blower starting
and so what is the problem?Br. Jamie, osb
Sounds like you have an open limit or flame rollout switch.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
