They ain't all pretty or ready for the Miss America Pageant..
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,613
    This was a tight budget repipe for retired folks with limited income.  I have before pictures in another phone but it had
    1) A domestic coil almost rotted through.
    2) 1" Copper Eqaulizer that had the water feeder feeding in above the water line.
    3) Boiler takeoff busted down to 2"
    4) Totally blocked P Trol & pigtail.
    5) Operating pressure 7 psi
    6) Brown splunck gushing out of all the rads & Crappy old main vent.
    7) No Mixing valve on coil.
    All good now..running less than 1 psi.  Mad Dog 🐕
    realliveplumberRusty2
  • Mad Dog_2
    Boiler installed 8 years ago.  Mad Dog 🐕
    PC7060
    ethicalpaul Member Posts: 8,916
    Oh man Mad Dog, they deserved a horizontal header :sweat_smile:
    As we say in NJ, "Just sayin'!"
    Does the makeup water care where it's added from?
    I'm sure they were happy to have it running better though
    Mad Dog_2
  • realliveplumber
    realliveplumber Member Posts: 354
    Sometimes you just got to get it done.
    Mad Dog_2CLamb
    EdTheHeaterMan Member Posts: 12,422
    I want to see more of the Snow White on Ice pictures
    Mad Dog_2Erin Holohan HaskellRusty2PC7060
    edited November 2023
    No, because I know Mad Dog cares and wants to do it right. But he says the budget was super tight so I believe him.
    Mad Dog_2CLambSlamDunk
  • worldclasshvac
    worldclasshvac Member Posts: 40
    Still nicer than most of the new crap I see nowadays 👍👍👍
    Mad Dog_2
    EBEBRATT-Ed Member Posts: 20,344
    @Mad Dog_2 that must be the new type of steam vertical header I have been herring about LOL :):)
    I like that picture because even though it is wrong it is a perfect example of a boiler piped wrong that will probably work now without an issue.
  • Mad Dog_2
    That's a Long Island 🏝 C.O.D. Oil boiler special...see alot like that when people go without a Contract and a Legit oil company.
    I took a bath 🛁 on the job as it is, had to draw the line. I cut out all the domestic water 💧 and coil mess and repiped.  I died getting the oil coil bolts out.  The new ones went on with High-Temp grease and I also pipe dope both sides of the gasket so the next guy doesn't have to spend 60 minutes chipping it off like I did.  Thanks for the kind words fellas!   Mad Dog 🐕
    CLamb[Deleted User]Rusty2
  • tim smith
    tim smith Member Posts: 2,935
    Sometimes its not feasible to do what you want as not all have the funds to do this. I think the lipstick you put on the pig is just fine Matt. Now at least they have a functioning one.
    Tim
    Mad Dog_2CLamb
    edited December 2023
    That gasket will still leak in 5 years.... I don't know why, but every tankless coil boiler I installed. I would snug up the bolts. A year later, I would go back for the "free tune-up" I included in the boiler install contract, and found the bolts were loose. Retorque them and sign up the customer for a maintenance plan. The free tune up was a way to get in the door to sell the maintenance agreement. Worked over 86% of the time. Sold lots of maintenance plans that way. Those orange gaskets must shrink a lot over the first 500 hours of use.
    Mad Dog_2
  • The Steam Whisperer
    The Steam Whisperer Member Posts: 1,319
    The truly knowledgeable steam expert can usually figure out where the limits are and be able to get a good functioning system even if it isn't absolutely by the book. Kudos to you Mad Dog!!!
    ScottSecorMad Dog_2
