Buderus Logamatic 2107 Controller Installation
Clammy...He's on Find a contractor as well. The man is a Mechanical genius & Rocket Scientist 🚀 👌. .with over 45 years in the Business Mad Dog 🐕1
always blew my noggin how many heating guys can not deal with this control, seems like you have some good leads. The BFU sensor is semi-necessary to make this controller really sing. If it's a low-mass system, then it's not such a hot potato.1
Thank you for the referral. As a homeowner, it's very difficult knowing who's good and who's not. In addition, Bosch recommends going with technicians who have gone through their training which I suppose is understandable given the potential complexities of working with the Buderus boilers. The homeowner then has to decide whether it's "mandatory" to go that route or opt for a referral not on the list. Not easy!
1 -
In my younger days, I was afraid to say "I don't know how to work on that system". Now, as an older dude in my 50s, it flows right off my tongue. Anyway, good luck.
1 -
Hey guys, I'd like to get a second quote if someone here has a suggestion. Again, I'm located in the Morristown NJ area. Thanks in advance for your recommendations, Gary.
Aren't they wired the same, only the programming is different? I'm not sure, but I think the only physical difference is the ODR sensor. You're best bet is to read and understand the 2107 manual yourself. Not too many techs know it.
HVACNUT, I think that's probably true although I'd have to chat with the Bosch folks to be sure. But that doesn't mean I can do the wiring up myself. And to your point, yes it's been a bit of a trial to find someone who knows how to do it. Which is probably why I'm getting expensive quotes for work that according to Bosch should only take 1 1/2 - 2 hours to do properly.
"should only take 1 1/2 - 2 hours to do properly".
That's a tad on the fast side unless someone does this all the time (no one does these "all the time". )
Be careful to not quote that to your heating person, that could get dicey.
The control replacement is plug and play …. I recommended to change the stainless well that comes with it...
Hi plug and play …. stainless well
How can I find a qualified technician in northwest New Jersey with verified experience installing Buderus products, specifically to switch my 2105 Controller to the 2107?
Lots of phone calls, good luck, the 2017 is a critter than doesn't get much love.
