Help! Attack of the pinhole leaks.
2»
    Jamie Hall Member Posts: 27,776
    I'm with you, @ChrisJ . Further, no one seems to be following up on water quality... or exterior contaminants getting on the pipe, like cement dust...
  • ChrisJ
    ChrisJ Member Posts: 17,663
    Silly idea but.
    If there was insulation on that pipe, and a coal bin near by, would that explain this?
    I doubt that's the situation but I seem to recall coal dust being corrosive to copper or am I remembering wrong?
    hot_rod Member Posts: 28,263
    As you can see it would take a troubleshooter with many skill sets to determine pin hole causes, plumbing, electrical, chemistry. Plus time and patience, and equipment to perform all the tests. And $$!
    With water quality, it can change from time to time. Based on the source, the chemicals used at the treatment facility. Was the dosers out of spec for a period of time?
    My city water report notes that the water numbers will change over the year. They now show a range for hardness, and other readings instead of a specific number. On other tests it indicates within EPA range, with no specific number?
