Main Pipe Sizing?
Is there a chart for minimum vs ideal main sizing? I realize bigger is generally better but I've got a quick question.
I have two mains. One is about 35-40ft long and is 2" and has an EDR load of about 115. This one is fine.
The other one needs rebuilding as a couple of radiators have been moved and it is piped very poorly. It is about 30-35ft long and is currently 1.5" with an EDR load of about 125.
It heats okay but I'm redoing some near boiler piping and I'd like to straighten this out. Should I go 1.5" or 2" like the other main?
Thanks guys!
    You really should have a copy of The Lost Art... the answer's in there. However. Is this one pipe or two pipe? It makes a difference.
  • AdmiralYoda
    AdmiralYoda Member Posts: 798
    @Jamie Hall Good point! That has been on my things to buy list! It is single pipe, counterflow.
    Really should be 2 inch
    pecmsg Member Posts: 7,284
    One of the few times “Bigger is Better”!
  • AdmiralYoda
    2" it is!
