Smoke detector that shuts power off
Curious what's out there as I'd like something for use with 3d printers (120V 15A) in case something elephant foots while I'm not there.
I'd rather something very smoke sensitive, like an Ionization smoke detector rather than heat triggered.
The typical interconnected smoke det has a 3rd wire to activate the rest of the connected detectors.
I have never measured the voltage of that red wire when in alarm....never needed to.
It could energize a SPDT relay to open the NC contacts.
Just be cautious of the load of the 3-d for the contacts.
Maybe you want the PE smoke detector, thought to be better/quicker than the ion ?2 -
In my experience PE is much less sensitive than ion.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Ion were less money so were the common install.
Never looked into the PE.....but wait....no Radioactive parts!!0 -
There are detectors for integration with alarm systems with dry contact outputs that could trigger a contactor or sequencer.0
https://support.firstalert.com/s/article/rm4
Looks like they make an RM4 relay that can do this.
Though I wish it was rated 20A.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
You should probably trigger a sequencer or stack of sequencers if your load is anywhere near 15 a anyhow.
I'm not sure if cutting the power is going to make a huge difference by the time enough plastic is burning to trigger the smoke detector.0 -
Have you seen this one?
Made with 3D printer in mind
https://dockingdrawer.com/products/safety-interlock-outlet-with-smoke-and-heat-sensor?variant=40449767505963
Though the smoke sensor isn't UL listed1 -
Try an Ansul Hood system, it has electric dry contacts if activated.
My other concern is the TR receptacle looks extremely cheesy.
No need to worry about the printer causing a fire if the outlet can do it for me.
1 -
With how sensitive an ionizing smoke is directly over the printer, it would probably do a lot of good. I'd expect it to self extinguish if caught soon enough. Of course, I could be completely crazy too, but that's what I think right now.mattmia2 said:You should probably trigger a sequencer or stack of sequencers if your load is anywhere near 15 a anyhow.
- 129 Chimneys & Flues
