Paint recommendations for steam radiators
branimal
branimal Member Posts: 301
I've stripped 4 CI radiators of paint and rust (lye bath followed by electrolysis). I've primed all the radiators to prevent further rusting.
Now it's time to paint. I'm using an HVLP sprayer so I'm not limited to rattle cans. I can buy paint by the quart or gallon.
Anyone have a recommendation on a good paint?
I've used both Rustoleum (not high heat) and Benjamin Moore Satin Impervo oil -alkyd paint in the past. The BM paint seems to hold up a little better to little nicks from moving, but not leaps and bounds better.
Thanks.
    Jamie Hall Member Posts: 27,498
    edited April 2023
    If for some reason you do need an oil paint, the Impervo is good. I have found, however, that Benjamin Moore Aura, an acrylic, or the equivalent from Sherwin-Williams works just fine -- and has more colours available and far less odour problems.
    mattmich
    EdTheHeaterMan Member Posts: 12,427
    I like silver for radiators. But that's just me.
    branimal
  • HomerJSmith
    HomerJSmith Member Posts: 2,791
    edited April 2023
    Ed, I wonder about the reflectivity of silver paint or any metallic paint. Transmissibility of heat energy is the most important factor. A paint that transmits the lowest emissiblity would not be my choice. My understanding that black emits the most radiation, but what'da I know.
    Paint a radiator with multiple paints and get an IR gun and check it out. I'm sure someone in the world has done this.
    reggi
    ethicalpaul Member Posts: 8,920
    It's basically metallic paint if you want less radiation, or any other color if you want full radiation.
    https://heatinghelp.com/systems-help-center/radiator-paint-colors/
  • reggi
    reggi Member Posts: 539
    It's basically metallic paint if you want less radiation, or any other color if you want full radiation. https://heatinghelp.com/systems-help-center/radiator-paint-colors/
    :o  So if your further radiators seem to not heat up quite as much as the rest of system then perhaps painting the nearer ones to the heating source black will give the steam a chance to fill the further ones perhaps painted silver ? A type of regulation that may of been done in the past ? Maybe when aàaàoil / gas came about and the season long coal fire was no longer?
    @DanHolohan what do you think ? Ready to jump in the time machine or did you retire that to your museum 😮
    One way to get familiar something you know nothing about is to ask a really smart person a really stupid question
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,633
    edited April 2023
    ½I did metallic High Heat Rustoleum in Copper...The others are flat black with Gold Leaf for the raised filagree.  Mad Dog
    HomerJSmithreggibranimal
    If steam isn't reaching a far radiator, it isn't likely to be fixed by painting the near ones metallic IMO. The problem is incorrect venting or a water trap due to sagging.
  • reggi
    I was just reading a older book and they were talking about painting those radiators with the raised designs in two color scheme.. ( I don't remember the exact process but) paint the entire rad the color of the highlighted areas  (finished) .. then you brush on the paint that the radiator is going to be and before it sets wipe the paint off the raised areas you want the other color.
    Now you get the general idea... I'LL post it if I come across it again soon..
    How did you do yours ?
  • reggi
    True.. what about  2 identical rooms , everything being equal, one having a silver metallic painted radiator, the other a flat ? Black painted radiator, with the thermostat in another room, how would the rooms with the different color radiators heat and retain heat after the thermostat is satisfied ?
    If the Black painted radiator stayed warmer, longer, wouldn't that lessen the calls for heat and save fuel ?
    The black one would radiate its heat faster according to what we've been told.
    But regardless of that detail, I can't see the difference being noticeable to the thermostat or the residents. In most calls for heat the radiator isn't going to be fully heated anyway.
