Steam pipes banging
Ok relatively new boiler, one pipe system, pipes pitched the right way but still banging pipes to radiator on second floor. Can hear surging sounds also
any suggestions
thanks
  • KC_Jones
    KC_Jones Member Posts: 5,936
    “Relatively new”. Was it skimmed after installation?  If not that could be causing the surging.  The other potential cause is an improperly piped boiler.
    Pictures of the boiler and piping would help with the remote diagnosis.  Make sure you have pictures showing the boiler and piping in one shot from a couple different angles.
    2014 Weil Mclain EG-40
    ethicalpaulmattmia2
    ethicalpaul Member Posts: 8,922
    Yes we love to see pictures of correctly-piped boilers, please share!
    pecmsg
    pecmsg Member Posts: 7,189
    If @EzzyT did it its fine! :D
    ethicalpaulmattmia2
  • JohnNY
    JohnNY Member Posts: 3,382
    Getting the banging out of steam systems is what I do.
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
    Long Beach Edethicalpaul
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,644
    Pictures....Please!!!! Mad Dog
  • GBC_illinois
    GBC_illinois Member Posts: 104
    edited February 2023
    The main solution that I found to eliminating water hammer / "radiator banging noises" / sloshing sounds in the pipes was to lower the steam pressure; you may find that the newly installed system was set too high. As "The Lost Art of Steam Heating" by Dan Holohan says, you should run on the lowest pressure that will effectively heat your radiators, and you might need to experiment a little to find out what that is. The system I have now (for a multi-unit condo building) was installed at 7psi, but after some tinkering, I now run at 0.75 psi (12 oz). It heats perfectly, and the water hammer is gone.
