Heat in baseboard zone turned off
CarlTeravainen
Member Posts: 2
Have a relatively small 2 zone water baseboard system, 1st flr/2nd flr with tankless. I'm getting what I believe to be migration or "ghost " flow, whatever the correct term, to the 2nd flr zone with tstat turned off. Circ for each zone followed immediately by flochek. No other flow controls. Just a bad check valve or could a different piping configuration help this? Can checks be too close to circs? Any reason not to add spring checks on both sides of each zone? This seems an easy fix but if there is a more "correct" solution I don't want to overlook it. Thanks for reading
First pic is return. 2nd flr is black circ.
after correcting the mounting of your circs, i would open up the checks, clean them and see if they are working correctly.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
