Recessed lighting opinions
I'm looking to do recessed lighting in our bedrooms and maybe eventually the kitchen.
I see plenty of options and different styles so I'd like to see what others recommend.
Not really so much color temperature, but the style of light (snap in vs retrofit etc) as well as 4" vs 6" etc.
I see some offer things like a ring around it as a night light as well. Color changing etc
Brands?
My thoughts right now were 6 4" 9watt led ones per bedroom that snap onto a hole in the sheetrock. 4 on 1 dimmer and 2 on another dimmer away from the bed that can be used as night lights etc.
The bedrooms in question are roughly 10x16
I used the halo 4” color selectable snap in type. Very nice units and the the package (1/2”) allow you to place the light where you want even under joists.Be sure to leave a service loop in the supply wire so the power module can be pulled through the hole as required for future service.Re the dimmers I use Lutron Caseta Smart Home Dimmer. One control head paired with remotes that can be in placed in standard switch box or directly to wall using their adapter.0
How old is the building? There could be asbestos in the joint compound/texture, so over 50% to 100% of the drywall surface. Asbestos drywall joint compound (mud) was used up through the early 1980s (some claim longer).Author of Illustrated Practical Asbestos: For Consultants, Contractors, Property Managers & Regulators0
Didnt know that. I knew about "popcorn" textured ceilings possibly containing asbestos, but not the drywall mud too. It was everywhere.FStephenMasek said:Asbestos drywall joint compound (mud) was used up through the early 1980s (some claim longer).
Do you happen to know if it was the more dangerous type of asbestos ? (I forget the same, but the one that is short rods)
Currently in building maintenance.0 -
I believe asbestos is still in talcum powder. There were lots of patching products with asbestos so even if you test original materials you could disturb that. Then what happened to the scraps and such during construction.
Apparently some of the plasters especially those used in the era of rocklath.
oh, right, can lights. i used some halo retrofit cans with led inserts.
size really all depends on your lighting design and what instrument you need to put the light where you need it and what form you can get that in.
color changing is really a gimmick.0 -
@ChrisJ.. Do you have any tubing in the area that will have the resessed lighting ?0
The main house is 1860s but the section in question is much newer, I think between 1900 and 1910. However, the sheetrock ceiling was done in 1987.FStephenMasek said:How old is the building? There could be asbestos in the joint compound/texture, so over 50% to 100% of the drywall surface. Asbestos drywall joint compound (mud) was used up through the early 1980s (some claim longer).
That said, I have to think the amount of exposure someone would have using a drywall circle cutter even if there was asbestos in the joint compound would be minimal.
No,Derheatmeister said:@ChrisJ.. Do you have any tubing in the area that will have the resessed lighting ?
Why do you ask?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
@MikeAmann I think you bring up a good point I didn't really think of.
I had assumed the fixtures would at least have a foam gasket to seal against the ceiling?
I could run a bead of caulk around it before pushing it up, but that would make changing them a whole lot of fun.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
How much lightning do you need in a bed room? Would a couple floor or nightstand lights work. Seems all can or recessed lights go out of style
my son put a bunch of LED recessed in his basement
even being dimmer rated they still flicker as they dim
they are much easier to install compared to the tall steel can type, howeverBob "hot rod" Rohr
Living the hydronic dream1 -
https://www.amazon.com/Mounight-Selectable-Ultra-Thin-Can-Killer-D6JB14W2K-6/dp/B09QLWVPJB/ref=sr_1_40?crid=1ZGENLLLJRIZ8&keywords=amico+6+inch+led+recessed+lighting&qid=1673104190&sprefix=amico,aps,108&sr=8-40. My son just used these in his master bedroom addition.
Works with Alexa by using a smart switch. the center will get full bright or use the Halo feature as mood lighting. He is pretty happy with them.Edward Young Retired
2 -
Recessed luminaires that penetrate the attic ceiling or thermal envelope must by ICAT-rated. Insulation contact air-tight. They have a gasket to the ceiling and a high limit snap disc switch that prevents overheating. LED cans have eliminated many of the problems with cans overheating. Still, anything made by man can and will eventually fail. Follow the IRC1
A better way to do it is to caulk a baggy sheet of plastic over the whole thing, assuming it is rated for that and you have access.ChrisJ said:@MikeAmann I think you bring up a good point I didn't really think of.
I could run a bead of caulk around it before pushing it up, but that would make changing them a whole lot of fun.1 -
Except Monitor Top refrigerators.
Get it right Bob.....
3 -
Two of the bedrooms are for the kids, so in their case they do a lot more in their than sleep.
For my room I could get by with a candle. No, seriously, I could.
That said, style and trends do not tend to effect me much.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I avoid can lights where there is insulation above it. Like others have said, in that case you are punching a hole thru the thermal envelope of the building. That said I have made extensive use of 6" new work can lights in my basement, and the small 2"(I think) old work led can lights in my kitchen. The reason I used them is functionality. With a 7ft ceilings in the basement I just don't have much head room, and with the kitchen I have ones that can be directed, which are all pointed to the counters to provide task lighting.
Personally I've found I like the smaller lights over the big ones but that's just a difference in style and taste.1 -
Is this guy serious right now?JakeCK said:I avoid can lights where there is insulation above it. Like others have said, in that case you are punching a hole thru the thermal envelope of the building. That said I have made extensive use of 6" new work can lights in my basement, and the small 2"(I think) old work led can lights in my kitchen. The reason I used them is functionality. With a 7ft ceilings in the basement I just don't have much head room, and with the kitchen I have ones that can be directed, which are all pointed to the counters to provide task lighting.
I can't tell if he's bragging, joking, or serious.
I'm 5'6 and my head rubs on the joists above me in the basement...............
@JakeCK The only part of me that's partially confused is you calling them can lights. The one's I'm considering, well, primarily considering look like pancakes that snap into the sheetrock, so there's no "can". Just the LED, lens and junction box. But, you are right, it would be making a hole in the ceiling, but as @Bob Harper said that hole should be fairly sealed.
1 -
You really need to look for fixtures that properly diffuse the light and that dim properly. There are a lot of fixtures both inexpensive and expensive that don't get the technical parts right. If it is poorly diffused the light will be harsh and difficult to look at, like those tube replacements they use in convenience store coolers that have no diffusion.1
mattmia2 said:You really need to look for fixtures that properly diffuse the light and that dim properly. There are a lot of fixtures both inexpensive and expensive that don't get the technical parts right. If it is poorly diffused the light will be harsh and difficult to look at, like those tube replacements they use in convenience store coolers that have no diffusion.
Flickering won't be tolerated in my case.
But for air concerns here's what I see on cheaper ones at homerSingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
My only comment is whatever you decide on, try to find something that will still be available if one dies in a couple years. I put some in my kitchen during a remodel in 2019, one died and I couldn’t get an exact replacement so now I have one oddball that looks a touch different, is a slightly different color and is a tad brighter.3
I like Halo usually the 4". They have a switch on them to adjust the color.
You can use a hole saw or circle cutter inside a plastic container and virtually catch all the dust. You can by one or make one....many u tube videos on this.
The Halo are only 1/2" thick and are IC rated to be buried on insulation.
Some are dimmable and some are not. Be careful with the dimmers. Most all the trouble with LED's come from dimmer issues1 -
I put some halo cans in my kitchen about 7 years ago. At the time it was a housing with an led trim that had an adapter that screwed in to the edison socket. I have been mostly happy with them. i have one that is acting a little weird, i pulled it out and reseated the adapter in the socket and it got better but is still doing a little buzzing.
With the "airtight", be careful, i think that refers to some standard that is not in fact air tight. The halo cans are called air tight but they have some holes for the clips that secure it to the ceiling and this cheesy super low density foam gasket on the trim. The spiders have no problem finding their way through them.0 -
The reason for asking was that there are claims that UV from the bulbs leaking past the can could deteriorate the tubing.0
Derheatmeister said:The reason for asking was that there are claims that UV from the bulbs leaking past the can could deteriorate the tubing.
No pex anywhere near that no.
But I've wondered how much uv decent LEDs actually produce.
Uponor claims you can't put pex near LEDs but I took that as more of a cover their a..... Rather than realitySingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Is this guy serious right now? I can't tell if he's bragging, joking, or serious. I'm 5'6 and my head rubs on the joists above me in the basement............... @JakeCK The only part of me that's partially confused is you calling them can lights. The one's I'm considering, well, primarily considering look like pancakes that snap into the sheetrock, so there's no "can". Just the LED, lens and junction box. But, you are right, it would be making a hole in the ceiling, but as @Bob Harper said that hole should be fairly sealed.
Ah you mean pex etc.ChrisJ said:Derheatmeister said:The reason for asking was that there are claims that UV from the bulbs leaking past the can could deteriorate the tubing.
I've seen a lot of commercial stuff deteriorated from the uv from fluorescents that are on all the time both below and above the ceiling.0 -
mattmia2 said:
I've seen a lot of commercial stuff deteriorated from the uv from fluorescents that are on all the time both below and above the ceiling.Derheatmeister said:The reason for asking was that there are claims that UV from the bulbs leaking past the can could deteriorate the tubing.
Do normal interior led lights produce a lot of UV?
Do normal interior led lights produce a lot of UV?0 -
I don't specifically know about the electronics, what the distance of the transition is or how they control that, but i have had a few LED lamps where the phosphor came off of one of the dies and that led was purple and not as bright, so i suspect at least some LEDs are making uv and converting it to visible light with a phospher.0
OK if price is no object. I would do a halo 4 in LED with 3000k bright light. The fixture is a ML4 led 3000k that fits in the 4 inch can. The light is expensive and so is the trim but the light output is unmatched in feel. The other options in the line are 5 and 6 inch. The 5 and 6 inch don't have the same light feeling so don't was the money on them I tried. The HALO ML4 is what the 12 volt MR16 bulbs used to be but much brighter but great light to the eyes. I first started using them in kitchen and was hooked. Now they are in the kids bedrooms. They do dim and don't flicker. Good Luck2
Ive put in 100s or the thin type LED lights. Halo, NDR, Topaz, are all brands I've used. They all are pretty similar with color selection switches (tunable color temp) and are very easy to install.
For what they are, they are very close to air tight, and I know you Chris... use painters caulking around them they will be air tight.
One word of caution, cut off the low voltage connectors and run low voltage wire and remote mount all the drivers. It is the driver which fails (and gets warm). So if you have them mounted in an accessible location with your Romex going to them they will be easy to change in the future.
If you don't like them in 20 years, just remove and patch the sheetrock....no lathe and plaster patching!!!Serving Northern Maine HVAC & Controls. I burn wood, it smells good!1 -
Solid_Fuel_Man said:Ive put in 100s or the thin type LED lights. Halo, NDR, Topaz, are all brands I've used. They all are pretty similar with color selection switches (tunable color temp) and are very easy to install.
How far would you think it can be moved? I'm guessing it depends on the size wire I splice in?If I could mount them all by my attic stairs by the door that area stays pretty reasonable especially compared to the attic.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
@ChrisJ - the two conductor feed wire from the driver is pretty small but only runs about 12”. I’d say 18ga low voltage wire (or tstat wire) would work well up to 30’. You can buy the halo type at Lowes or Homers. Pick up one and give it a shot and be sure to let us know what you find!
Good idea @Solid_Fuel_Man!1 -
The size will depend on how much current the fixture draws and the distance. Since it is low voltage the voltage drop can become significant depending on the current and the distance. If you put more than one fixture on a cable then there will be more current and more voltage drop. Dropping 1v because of the resistance of the wire and the current draw is much more important at 12v than 120v.0
They're typically 9 to 12 watt lights.
I'm thinking the current probably isn't very high but I have no idea what voltage they run the LED's at.
At the rate which this technology changes, there's no way to ensure something will still be available in a couple of years. The best approach is to lay in a few spares when doing the job and keep them stored should failures occur.Matt_67 said:My only comment is whatever you decide on, try to find something that will still be available if one dies in a couple years. I put some in my kitchen during a remodel in 2019, one died and I couldn’t get an exact replacement so now I have one oddball that looks a touch different, is a slightly different color and is a tad brighter.
My only comment is that one ought pay attention to more than just color temperature when selecting the product. Color Rendering Index (CRI) is also very important. I rejected anything less than 90.1 -
If you're interested in LED strip lighting you could get a lot of good information from the "LEDs ARE AWESOME" group on Facebook.0
Eventually a replacement will be required so it’s important to include a service loop to allow for replacement of tbe control module as well as the head assembly. I don’t think the form factor is going away.0 -
12v 12w is 1a. is is half an amp at 24v.ChrisJ said:mattmia2 said:The size will depend on how much current the fixture draws and the distance. Since it is low voltage the voltage drop can become significant depending on the current and the distance. If you put more than one fixture on a cable then there will be more current and more voltage drop. Dropping 1v because of the resistance of the wire and the current draw is much more important at 12v than 120v.
a 50 ft piece of #16 cable is .4 ohms. if you have 5 fixtures on it at 5a v=ir, v=5*.4 v=2v so if your supply is 12v, it will be 10v at the fixture.0 -
They run at something like 29Volts or something odd like that.
I'd say 16 or 18 gauge is good for any reasonable residential distance. Any appreciable voltage drop would just result in slightly lower light output. Nothing to worry about.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!1
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 99 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 53 Water Quality
- 41 Industry Classes
