Tankless Water Heater on Oil Burner
solarguyDC
Member Posts: 1
in Oil Heating
I have a tankless hot water heater on my oil boiler. I have recently installed new mini splits throughout the house that I use for my heat and air conditioning. I am trying to convert my domestic hot water over to an electric hot water heater but I want to keep the existing (working) boiler and hydronic radiators throughout the house as emergency heat if the power goes out. I am a solar guy so I am 100% energy independent and have enough battery storage to run off the grid for about 4-5 days. That being said I have a full tank of oil and frankly there is nothing wrong with the boiler I just don’t ant to bypass the tankless hot water heater and direct it to an electric one. If the power goes out for an extended period of time I can redirect the domestic water back through the boiler and get hot water that way until the power/sun comes back. Any suggestions on how to achieve this if possible.
A manual system where you need to turn valves?
Or an automatic system that monitors temperature and makes the decision.
Solar delta T controllers can make the decision, a 3 way motorized valve does the switch, for an automatic system. I have a bunch of 12 and 24VDC controllers if you want to use your battery to run the control.Bob "hot rod" Rohr
Living the hydronic dream0 -
