Does this old acretherm thermostat use asbestos?
I don't know much about thermostats and was just curious if anyone knows?
    pecmsg Member Posts: 7,281
    No t-stats used asbestos.
    Mercury is a possibility
    Nova35653
    mattmia2 Member Posts: 17,470
    It wouldn't surprise me if there is a tiny amount of asbestos in some wire insulation or insulating washers or especially in the insulation in some heat anticipator resistors.
    Jamie Hall Member Posts: 27,582
    But not enough to worry about, unless you are an absolute fanatic.
    The liquid in the thermometer will be alcohol.
    The active element is a bimetal.
    EBEBRATT-Ed Member Posts: 20,481
    probably a series 10 three wire stat
  • unclejohn
    unclejohn Member Posts: 1,833
    Snap action switch
