LARS Mascot Service in Seattle - ERROR
Sarah110WA
Member Posts: 2
Hi,
I have installed LARS Mascot FT boiler 2-3 years ago , it was working fine till 3 days ago when I started getting error code 10 - Combustion and ignition problems . The weather is cold (46 F) and I don't have heating or shower at home. I have restarted the boiler multiple times per technical support but still receiving the error code. I have called the customer service but they don't serve residentials in Seattle area and I am not able to find a service around my home.
Please help. Any suggestions or tips would be really appreciated. Or any service team that can fix with a reasonable price.
If I knew this boiler has such a poor or no support I would never purchase it.
Need a model #
Mascot FT natural gas
Model MFTCW0 -
Combustion error. One or more of the following: Not enough air, gas, or spark.
See if you can see it trying to ignite. If it is make sure your vent is open and combustion air intake is open.
MFTCW is not enough info. In the smaller unit there is a screen on the intake that could get clogged up with dryer lint, PVC pipe shavings from poor install, bird nests, etc.
Any decent HVAC guy should be able to service the unit. Far as I know no manufacturer is going to come to your house to service a unit.1 -
Manufacturers support their dealers and licensed heating contractors who in turn support their customers. If you bypassed the contractor by doing it yourself, then this can be the effect. I know that’s not what you want to hear, but it’s the truth.
I would recommend that you locate a contractor in your area who installs and services Laars and be up front with them about your situation and ask if they’ll service it. And be prepared to pay what they charge - if you can get their help.Bob Boan
Shopping for price 1st usually leads to other issues!Sarah110WA said:Hi,
1 -
- 120.2K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 30 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 152 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 736 Plumbing
- 5.2K Radiant Heating
- 356 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 69 Job Opportunities
- 14 Recall Announcements
