Lots of white smoke from neighbor's chimney
No other chimney in the neighborhood belches such smoke, which is probably condensed water, because it vanishes. But I'm wondering if there's a problem with their heating system, for instance: with a water-based system, there could be a hole in the heat exchanger, spurting water into the combustion chamber, causing steam? This is the second year now that I notice this about that chimney, every morning when the weather is cool.
    Jamie Hall Posts: 27,738
    Most likely.
    EBEBRATT-Ed Posts: 20,946
    is it oil or gas? Gas will look like white smoke when it is cold outside as the flue gas condenses.
  • ChrisJ
    ChrisJ Posts: 17,645
    I get some white smoke when it's really cold out. Near or below 10F
    I don't think I notice it if it's in the 20s out though.
  • is it oil or gas? Gas will look like white smoke when it is cold outside as the flue gas condenses.
    Why would fuel type matter? A water leak into any combustion chamber would produce steam.
  • bburd
    bburd Posts: 1,324
    edited October 2022
    Gas fired systems produce visible water vapor in the exhaust whenever it’s very cold outside. Oil fired systems don’t, or at least not until it’s a great deal colder, unless there is an internal leak in a steam boiler above the waterline. The difference is due to the much higher hydrogen content of gas, which produces more water vapor in the products of combustion.
    Bburd
    Steamhead Posts: 18,834
    If it's a steam system, the boiler probably has a leak above the waterline.
    mattmia2 Posts: 17,995
    Could it be a condensing boiler or furnace using the chimney as a chase?
    HVACNUT Posts: 7,656
    @meofbillions, is your neighbor even aware?
    Quite true that a gas fired boiler or furnace will produce some white smoke -- but not a lot of it. If it's lots of white smoke, it's a leak.
