Old sparco/honeywell mixing valve.. TLC for the o-ring ?
Have a 20yr old Sparcomix/Honeywell AM 100-145 mixer in my hydronics.
I took it apart thinking I would buy the rebuild kit.
Not finding it (obsolete).
Plan is to yank all this hardware out next summer, so Im going to reassemble it and use it one more season.
However.. I should at least clean and get some plumbers grease on the body o-ring. After 20 years, Im imagining that oring isnt going to come off in a happy way as-is.
What can be done to soften it up for removal ?
  • Not a whole lot. And by now it may have taken a set and be difficult to get seated again so be cautious. How big is it? Many really good auto parts stores and some hardware stores have assorted o-rings.
  • WD40 will help remove old o rings. It is probably worn or list it resiliency and may not seal
    You could buy a new one and swap the internals
  • Not too large.. Im guessing an inch by a 16th ?
    I've got a box full of varying sizes of o-rings for my auto work -- that size is in there (well, the 1/16th is a little thin not sure I go that thin). Try a hardware store or an autoparts store.
  • Look up Honeywell part # AMU200-RP. It's a current offering from Honeywell. And they also have complete rebuild kits AM-1-025RP and AM-1-030RP (has 1070 element).
