Lochinvar fire tube model choice w/ current system pics
gyrfalcon
Does anyone have any input on the knight vs Nobel models? Is the floor mount version more desirable in any way?
Slant Fin Galaxy GG100(1986) , 2 zone hot water baseboard, T87 Honeywell thermostats.
Floor vs wall mount usually depends on where you are trying to put it. If you can tuck it away on a wall then you want wall mount, if you are putting it in the middle of a room then floor mount is probably what you want. Just flexibility in how you plan the installation.
Others would know more about knight vs nobel but I think it is a different hx series and more or less things that are configurable, one has a controller that will do more.0 -
The Knight has a lot more useful control features. Wall hung usually have top, bottom, or both connections, floor mount are usually side port. So look over the piping differences if space is at a premium
I have put floor mount boilers up on strut racks, ands shelves before the wall mounts became availableBob "hot rod" Rohr
Living the hydronic dream0 -
It looks like the knight has higher water capacity too.Slant Fin Galaxy GG100(1986) , 2 zone hot water baseboard, T87 Honeywell thermostats.0
I believe the Knight has a much larger HX. I’m not up to speed on all the differences, their online literature shows features and cutaway views to compare HX size and connection locationBob "hot rod" Rohr
Here is what I’m looking at every day I open the boiler room door. I’m hoping to get the plumbing and orientation cleaned up when the boiler is replaced. As mentioned in the previous posts from last season, the current boiler is a slant fin galaxy 100k btu from early 80s. Domestic water is a Richmond 50 gallon, 40k btu 2-3 yrs old.
Slant Fin Galaxy GG100(1986) , 2 zone hot water baseboard, T87 Honeywell thermostats.0 -
Everything works fine , btw. It’s just kind of a mess.Slant Fin Galaxy GG100(1986) , 2 zone hot water baseboard, T87 Honeywell thermostats.0
That boiler has a bad case of dandruff. What water temps are you running?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Aquastat is set to 180Slant Fin Galaxy GG100(1986) , 2 zone hot water baseboard, T87 Honeywell thermostats.0
This picture is from top down.
I still want to have a pro clean it and do combustion test to tide me over until replacement timeSlant Fin Galaxy GG100(1986) , 2 zone hot water baseboard, T87 Honeywell thermostats.0
I didn’t show pics of pex and shark bite! It’s in there. I feel like I’m in a Mario bros. Nightmare! Yea, revamp is definitely needed.Slant Fin Galaxy GG100(1986) , 2 zone hot water baseboard, T87 Honeywell thermostats.0
Does anyone have a clue where the white scaly stuff came from?Slant Fin Galaxy GG100(1986) , 2 zone hot water baseboard, T87 Honeywell thermostats.0
The "dandruff" coming down the vent is often a byproduct of flue gas condensation. What are your boiler temps? Is a portion of the flue pipe outside of the heating envelope?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Take a look at Viesmann boilers as well. We have installed a few and have been impressed with them. I like the Knights as well. I know for my wholesale cost Viesmann is a better value in my area, but Lochinvar is popular. I would interview a few contractors and get some quotes. Make sure you get a load calc done to ensure a correctly sized boiler.
Owner of Grunaire Climate Solutions. Check us out under the locate a contractor section. Located in Detroit area.
Zman- The flue pipe does pass through the ceiling and goes up above roof for maybe 5-6 feet. As far as I know the aquastat is at 180. Boiler never runs for more than 5-6 minutes.offdutytech- from all of the contractors I’ve talked to, All have said Lochinvar for modcon option. For CI Weil CGA, Burnham 2 or Utica mgb-k ( all matching current btu of my Slant Fin-100k btu input. .. likely way oversized. However the one company who is very responsive to my questions agrees to use the 60k cast Utica since his calculations show my home to be 50k or less, as do mine. I actually hired this same company to install a 12k Mitsubishi mini split in my attached sunroom, so it now is a nice balance to my home instead of being an extreme . So far this fall I have only used this mini split to warm my house on 30 deg nights, the sunroom doors are left open to my living room. House is 63-65 in coldest , farthest bedrooms .Slant Fin Galaxy GG100(1986) , 2 zone hot water baseboard, T87 Honeywell thermostats.0
Mattmia2. That makes sense.Slant Fin Galaxy GG100(1986) , 2 zone hot water baseboard, T87 Honeywell thermostats.0
Not the Noble, love the knight fire tubes and their Squire indirect. Great matc up.0
