Radiator for Interior Bathroom
Greetings All:
I am doing a remodel project and we are relocating, what used to be a full bath w/ shower, to a simple hall bath. The existing bath had a small 2500 BTU radiator. I assume this was more for the fact the old bath had a shower.
My questions is: Now that we have only a small hall bath 3.5ft by 7.5ft, and the new bath is in the interior of the house, do I really need a radiator. Note we have not had an issue of the house feeling cold or drafty in the past.
  • bburd
    bburd Member Posts: 1,307
    The main drawback to leaving that radiator out would be if you set the temperature back when you are asleep or away from home. Without a radiator that room will take longer to warm up when the house is reheated to occupied temperature. Also, is there a heat load from a cold basement, crawlspace or slab below?
    Bburd
    Sonor3000
    Jamie Hall Member Posts: 27,419
    Unless it's a real hassle to keep it, keep the small radiator. No, you won't need it really to heat the room (unless there is a cold attic or basement) -- but it's energy demand is very small in relation to the sheer pleasure of finding that the bathroom is nice and warm...
    Sonor3000EdTheHeaterMan
  • Sonor3000
    Sonor3000 Member Posts: 16
    bburd, thanks for the feedback. The room is above a full basement which sits in the 60's during the winter months as it is well below grade. I say sixty, all I know is I can wear a T-shirt in the winter and feel comfortable :-).
  • Sonor3000
    Jamie: Thanks for the feedback. The only concern is the space since the bathroom is only 3.5 feet wide. And an "in swing" door makes the space tight.
    EdTheHeaterMan Member Posts: 12,322
    edited September 2022
    Just be careful with those 60s style tee shirts, they may lead to more dangerous substance abuse.
    Sonor3000PC7060
  • JUGHNE
    JUGHNE Member Posts: 11,562
    How about a heated towel rack?
    You could even hang your T-shirts on it.
    Ed, it that you in the center of the middle picture.....Woodstocker?
    PC7060
  • Sonor3000
    Just confirming no other comments... Thanks.... I may look at a smaller radiator (Burnham Radiant Radiators). Any experience with these smaller radiators?
  • bburd
    The smaller ones are fine, what matters is the EDR which measures heat output. You don’t need much for an interior room like that, if you match what was there you should be fine. You might also recess the radiator partially into the wall cavity.
    Bburd
    Sonor3000
  • Sonor3000
    Yep, I'm going off their table of information for 240 BTU/SQFT. Does that sound high for 180F Water Temp? I've seen other tables at 170 BTU/SQFT.
    hot_rod Member Posts: 27,553
    Even with radiant heat in the floor I added an electric towel radiator to my one bathroom. Ended up being a great addition we used it year around. Digital setback controls are also a nice feature.
    Sonor3000
  • bburd
    240 BTU/SQFT is for steam at 215° F. 170 is closer for 180° hot water. The existing radiator should have been sized for your system design temperature, so just match that.
    Bburd
    Sonor3000
