Why is Neighbor's A/C making Cicada and A-10 "Brtt" sounds?
Apologies, I'm a hydronic guy. I did work on A/C units like 20 years ago, but forgot everything.
My Neighbor has an outdoor A/C unit which every 2-3 minutes makes a loud hissing Cicada-like sound for 30 seconds followed by a loud "brrrrrrt" sound like from an A-10 cannon for a few seconds. Very regularly. Like clockwork.
Is this a common problem? Honestly, I can't believe his A/C is still working...it sounds like the outdoor compressor is killing itself.
What's happening?!
  • ChrisJ
    ChrisJ Member Posts: 17,536
    Is the condenser fan running
  • pedmec
    pedmec Member Posts: 1,469
    what does a cicada sound like???
    EdTheHeaterMan Member Posts: 12,556
    edited June 2022
    Sounds like @Steamback's neighbors A/C unit
    Dah!
    almost like a cricket but different.
    Here is a video
    https://www.youtube.com/watch?v=cprkGk_KW0o
    ChrisJ
  • JUGHNE
    JUGHNE Member Posts: 11,609
    Cicada could sound like a high pressure relief valve opening and then the "brrrr" sound the valve closing and compressor continuing to run.
    It may die soon.
    ratioSTEVEusaPA
    And like the Cicada, your neighbors air conditioner may be ready to mate with a Female A/C. The opposite sex of an A/C unit. The reverse cycle A/C
    AKA Heatpump
    And just like the Cicada, after the A/C finishes making that noise and finds a mate, the unit will just die.
    Isn't nature just great!
  • ChrisJ
    JUGHNE said:
    Cicada could sound like a high pressure relief valve opening and then the "brrrr" sound the valve closing and compressor continuing to run. It may die soon.
    That's why my first thought was that condenser fan.
    HVACNUT Member Posts: 7,545
    The Cicada noise could be a vibration or rusty motor shaft, the unit not level. The A-10 could be the contactor chattering.
