Where to place expansion tank when using buffer and multiple circs ?
Dave Carpentier
Dave Carpentier Member Posts: 640
Circs in; Boiler, Air Handler, and In-floor.
Depending on whats going on..
All 3 circs could be running, or
Only the AH and Boiler circs, or
Only the In-Floor and Boiler circs, or
Just the In-Floor circ.
  • kcopp
    kcopp Member Posts: 4,713
    Since there is a circ in the boiler the best place would be on the return going back to the boiler off the buffer tank.
  • Zman
    Zman Member Posts: 7,614
    edited May 2022
    I always like to be sure the circs with the highest pressure delta are addressed first. Radiant loops and water tube boilers are loops that meet that description.
    In your case, the buffer tank looks like the place. As long as everything is generously sized, it probably does not matter where on the tank.
    Albert Einstein
  • Dave Carpentier
    More like this ?
    EBEBRATT-Ed Member Posts: 20,793
    Yes
