Utica steam
Snowmelt
Snowmelt Posts: 1,454
edited April 2022 in THE MAIN WALL
Installing a 4 section residential steam boiler. I just hung up the phone with technical support. I’m using both risers. Technical told me to keep it two inch, after the tee going to the supply I could bump it up to 4 inch with a 2 - 4 reducer that’s what the original system is.
  • Post the boiler nameplate.
  • Snowmelt
    I’m sorry it was Utica 150,000 btu out
    Steamhead Posts: 18,830
    Is this "Utica Boiler" or "Utica Heating"?
    They're not the same..............
  • Snowmelt
    I’m sorry that was the old boiler which was a peerless
    ethicalpaul Posts: 8,986
    Post the actual model number if you have it
  • Snowmelt
    Peg 150 tomorrow I start the job . I don’t think I will do a drop header but I will you two taps
    Utica Boiler. Side outlets are 2" rather than 2-1/2".
  • Snowmelt
    PSB 5 D , I’m planing on using both risers I drew a little diagram
  • Snowmelt
  • Pughie1
    Pughie1 Posts: 136
    Pretty sure the PSB series is a Dunkirk
    John Pughe
    John Pughe
    It is. And the instructions clearly say DO NOT reduce the size of the steam tappings. That technical support person clearly can't read.
    I'd build a standard 2-1/2" drop header, using both risers and dripping into the equalizer as usual, and run the takeoff from that into the existing 4" header, dripping that below the waterline into the return before the Hartford Loop. This will give you some nice, dry steam.
  • Snowmelt
    Steam head so just pipe it as I see it………planing on going 24 inch with risers then make the mains 4 inch, just won’t be pretty I will do the best I can
