1930 Single Pipe Steam System with new Crown boiler
2»
  • delcrossv
    delcrossv Member Posts: 2,204
    Just swap the cap and vent then. Should help.
  • Sue777
    Sue777 Member Posts: 21
    So steam leaves the boiler on the two main pipes with the vents?  Then condensation returns to boiler theoretically moving same direction as those pipes wrap around and return to the boiler?
    Jamie Hall Member Posts: 27,520
    That's basically it -- in some ways steam is pretty simple.
    Sue777
    mattmia2 Member Posts: 17,227
    Probably not a bad idea for you to get "We've Got Steam Heat" or "The Lost Art of Steam Heating".
  • Sue777
    Do you favor one over the other?
    Not a bad idea for a beginner to have both. We've got Steam Heat is more of a basic introduction to steam heat and some of the simpler homeowner very mild DIY things. Lost Art of Steam Heating is a really detailed discussion of all types of residential and small commercial steam heat systems. With it you could -- with patience -- really come to understand how the system really works.
