Steam sq ft, if not listed on steam boiler
BirchLeaf
BirchLeaf Member Posts: 56
edited March 2022 in Strictly Steam
Is there a way to determine the steam sq. ft. of a steam boiler if it's not listed on the plate/sticker (by using other numbers listed)?
(I wrote down everything that was listed.)
    ethicalpaul Member Posts: 8,924
    BTU can be converted. Send a pic of the panel?
    BirchLeaf
  • BirchLeaf
    @ethicalpaul
    The boiler is gone (didn't take pic.) I wrote everything down, though.
    Input BTU per hr.: 112,500
    Heating capacity BTU/hr.: 90,000
    pecmsg Member Posts: 7,193
    Are you looking at a Boiler or a Steamer ?
    BirchLeaf
  • BirchLeaf
    @pecmsg
    It was a natural gas-fired steam boiler.
  • KC_Jones
    KC_Jones Member Posts: 5,936
    Is this the same boiler from your other thread that you listed as rated for 321 sq ft?
    2014 Weil Mclain EG-40
    BirchLeaf
  • SteamingatMohawk
    SteamingatMohawk Member Posts: 1,137
    p. 78 of Lost Art:
    EDR/4 = Lb/Hr
    BTU/Hr/960 = Lb/Hr
    EDR/4 = BTU/HR/960
    EDR = 4 * (BTU/HR/960) = BTU/HR/240
    90,000/240 = 375 EDR
    My math teacher always made me show my work.
    BirchLeaf
  • BirchLeaf
    @KC_Jones
    It's the OLD boiler that I'm trying to figure out sq ft of steam.
    (The NEW one is 321 sq. ft. steam.)
    Steamhead Member Posts: 18,625
    BirchLeaf said:
    @ethicalpaul
    If this is a Utica, Columbia or one of the Dunkirk boilers that might have any one of several names, it's 281 to 292 square feet.
    Consulting
    BirchLeafethicalpaul
  • KC_Jones
    With the 90,000 that would be with pick up factor, so the actual rating would have been what Steamhead said @281 sq ft
    90,000=375 EDR
    375/1.33=281
    gerry gillBirchLeaf
  • BirchLeaf
    edited March 2022
    You guys are amazing. Thank you all so much!
    @Steamhead You're right! Certified by Dunkirk Radiator Corp. It said installed in 1985, it ran wonderfully, I loved it, and I bet it could have been repaired.
  • SteamingatMohawk
    @KC_Jones Thanks for the "adjustment". I was just doing the simple math.
