American Severn steam boiler. No.25/1B-J1
Lin422
Lin422 Member Posts: 6
edited February 2022 in THE MAIN WALL
Water is leaking inside of furnace. I located 2 holes in the tank. Now I'm wondering if those holes are supposed to be there. If now how do I seal those holes to fill the tanks?
  • Lin422
    Here's a photo of thelable
    EBEBRATT-Ed Member Posts: 19,602
    If you have water leaking inside the boiler and it's not from an external pipe leak you probably need a new boiler
    Lin422
    Jamie Hall Member Posts: 26,842
    The holes are not supposed to be there. Perhaps more to the point, there will be more of them with time. Time for a new boiler -- that one has served you long and well. Do your homework, get it sized right, and find a really good steam person to double check and install a new one. Where are you located?
    mattmia2 Member Posts: 15,634
    Is that another hotel tray around the burner where the mounting plate rusted out?
    ayetchvackerLin422
    Steamhead Member Posts: 18,209
    Consulting
    reggimattmia2
  • Lin422
  • Lin422
    I found a really good stream boiler person. They changed the burner cover tray. They are going to tightened the tanks using the coil rod, use push nipples and check if leak still there. The leak is coming from the seams where it separated
  • Lin422
    Actually yes. But the previous didn't trust out. It was made of combustion chamber bowl material and crumbled when I was changing the bowl. Did not want to leave it open. But replaced with standard cover
  • Lin422
    No leak inside. From the external tank seams. I thought it was a joke.. No, just tanks separated from pressure from running without water
