Last guy said it runs fine...
STEVEusaPA
edited February 2022 in THE MAIN WALL
New Customer..."Can you fix it".
Me..."Nope".
--Hide the kids before viewing. You can't un see this LOL--
This was running before I got there. Customer said it keeps going off on reset, probably just needs a nozzle/filter.
Aluminum pan loosely covering the rotted front plate. Rotted 10" flue pipe into unlined chimney on a 100+ year old house.
ayetchvacker
    mattmia2 Member Posts: 14,799
    Was there a front plate there or did they just fill it all in with asbestos?
  • KC_Jones
    KC_Jones Member Posts: 5,887
    Would a hack even touch that one to "keep them going"? Serious question. I don't have a problem with old equipment, but when it's been obviously neglected and missing parts, that I'm guessing can't be acquired any longer...
    2014 Weil Mclain EG-40
  • SuperTech
    SuperTech Member Posts: 2,629
    Wow. I've seen some old boilers in bad condition but nothing remotely close to the horrific condition of that one.
    I don't know how that even the most clueless person would think that's OK to operate.  I can hear it all now..."it was working great a few days ago...".
  • delcrossv
    delcrossv Member Posts: 2,187
    The disposable aluminum pan is a nice touch. 😳
    STEVEusaPAMikeAmann
  • kcopp
    kcopp Member Posts: 4,603
    Thats some Serious Custom Shiz right there....
    EBEBRATT-Ed Member Posts: 18,972
    New plate on the front, new flue pipe and liner and it will run.
    But should be replaced
    If they keep calling people someone will get it running
  • STEVEusaPA
    It's worse than the pictures show. Chamber needs to be re-bricked. End cone and air tube rotted. Unlined chimney falling apart...won't be me.
    And no outside basement entrance, 30" wide rickety steps, and 60 year old oil tank.
  • STEVEusaPA
    The side facing the flame is nice and black/sooty.
    delcrossvSolid_Fuel_ManayetchvackerSuperTech
  • STEVEusaPA
    The guy has been texting me saying there must be some way to keep it running for another 3 months. I told him I wouldn't even run it for 3 minutes. I literally walked in, took the foil pan off, showed his wife what was going on inside, put the pan back over it, and took some pictures. Told her everything that was wrong and why I'm not even touching it. Didn't touch the burner or anything else.
    It's a row home. I actually recommended to her to line the chimney (no matter what they do), get rid of the tank, switch to gas.
    kcoppHVACNUTSuperTech
    Yikes!!
    3 strikes and your out!
  • bucksnort
    bucksnort Member Posts: 167
    What? Some JB Weld and a new roaster pan from the Dollar store and you're good as new. Did you ask them if they had any CO detectors?
    delcrossvdelta T
  • delcrossv
    I'm sure I'm dating myself but I have this picture in my mind of Karnak holding the envelope to his forehead and saying "They'll be pushing the reset button until spring"
    mattmia2kcoppbucksnortSuperTech
    Does the primary control look relatively new because they've been pushing the reset button daily for 30 years?
    delcrossv
  • Solid_Fuel_Man
    Wow! Wow, if  @STEVEusaPA recommended they switch to GAS it had got to be bad!
    We're you able to find a listing on the aluminum pan? I think it was just too covered in soot and you couldn't read it. Yup....
    delcrossvkcoppSuperTech
  • kcopp
    A case like that you may want to put in call. email/ letter to the local AHJ to tell them what you found and what you did (didnt do)... CYA on something like that.
    Solid_Fuel_ManSuperTech
  • Kickstand55
    Kickstand55 Member Posts: 115
    I've seen some poorly serviced equipment in my years. Dry base oil fired boilers, especially with flame coming out the back due to failed chamber, plugged flues, oil all around the burner spewing soot all over in a multifamily absentee landlord building.
    Hey, when they have a service contract to keep it running, you get what you get.
    I've condemned many. These days in NH, a Tech is not allowed to make the unit inoperable and leave the site. Just shut it off at the switch, Red Tag it, notify the customer and try to have them sign the work order. Good luck.
    I always call the local Fire Department and let them know the facts.
    SuperTech
  • Solid_Fuel_Man
    That place is the perfect candidate for electrification. A few hundred watt light bulbs in there, and you can remove the flue altogether, maybe some tin foil for some good reflective radiant barrier and call it a day. You should bring a few hundred orange extension cords with you. Make sure they are the 100 footers and that you only need to go 10 feet with them....
    delcrossvSuperTech
    HVACNUT Member Posts: 7,111
    I don't know, a little paint, a few flowers, a couple of throw pillows...
    All that stuff on top of the boiler including the baseball are keeping the top from blowing off.
    I really was hoping it still had a stack switch :)
    mattmia2SuperTechkcopp
  • STEVEusaPA
    It still has the hole in the flue pipe and the clamp attached.
  • SlamDunk
    SlamDunk Member Posts: 1,776
    Where they elderly? Or, on a tight budget? If so, I feel some empathy for them. My parents furnace looked worse than that before we replaced it. We went from 10 tanks of oil per winter to 2. We smack ourselves for not doing more for them when they were living. Maybe what I am feeling is guilt.
    STEVEusaPA
  • pell
    pell Member Posts: 25
    Did the customer ask, "Is it still under warranty?"
    Ironman
  • bucksnort
    Bet they still have the receipt.
  • scott w.
    scott w. Member Posts: 223
    May be a stupid question but how does some thing like this get to be in such bad shape? What made the hole in the bottom of the boiler? I wouldn't spend 5 minutes in that house.
  • STEVEusaPA
    If they do it's on parchment paper.
    delcrossvbucksnortSlamDunkkcopp
