Honeywell TH5220D Thermostat System Settings...might be a simple question
ukiltmybrutha
ukiltmybrutha Member Posts: 31
Hi, I installed a TH5220D for my old Goodman cple24-1c heat pump with AUX.
Should the correct setting be:
1 heat/1 cool heat pump
OR
2 heat/1 cool heat pump?
[img]https://i.imgur.com/xGYdlDl.png[/img]
  • ukiltmybrutha
    edited January 2022
    OR
    Thanks.
    https://imgur.com/xGYdlDl <----link to settings in question for this thermostat
    EdTheHeaterMan Member Posts: 12,581
    2 heat 1 cool
    Ironmanukiltmybrutha
  • ratio
    ratio Member Posts: 4,278
    2H1C with aux heat landed on the W2/Aux terminal & a jumper from Y2/E to W2/Aux. This isn't a dual-fuel (gas/oil heat vs electric) is it? That application will require some additional controls for correct operation.
  • ukiltmybrutha
    2H 1C....just tried it while waiting for responses. So "5".
    Thanks!
