American Standard UD100C948A Wattage
porchovilla
porchovilla Member Posts: 1
I am doing wattage calculations for a home backup generator and have an older (circa 1991) American Standard gas fired furnace, model UD100C948A. Coming up empty looking for information on the wattage, amps, etc. Anyone familiar with this model and how to think about running / peak wattage, or where I could look to figure this out? Any advice would be greatly appreciated. Thanks.
  • Ironman
    Ironman Member Posts: 7,927
    It should show the FLA on the data tag.
    Bob Boan
    pecmsg Member Posts: 7,282
    edited January 2022
    Starting and running are two different things. Starting amps can be 10 times higher then running.
    If there’s any computers envolved a clean sine wave is required.
    EBEBRATT-Ed Member Posts: 20,481
    full load amps on the name plate or easured with a clamp on ammeter x 120 volts will give you the wattage. Probably around 10-12 amos
