Can't turn radiator off
mg221b
Member Posts: 1
Hi everyone, I'm new here and made an account for this specific issue I'm having. I live in New York City, and my apartment building is over 100 years old. So, the radiator is quite old, as well. It has a radiator cover that I was able to remove, but I just can't figure out how to turn it off. I'm attaching four pictures- the first is what is underneath the radiator, the second is a front facing view of the radiator without the cover on. In the second two, I have circled the devices that I've tried tinkering with (I tried turning clockwise with pliers, and then with my hands and oven mitts) and they just won't budge. Any and all help or advice is appreciated. Thank you!
1 pipe steam system. Even if you could close the valve, they usually don’t work from age. Also on those types of systems the valves should be left open all the time.
Appears the handle has been removed to keep people from tinkering with it. I would do that if I had a building to maintain, but my system would also be working properly so people weren’t being overheated.
The only way to really turn it off is to stop the venting. The silver bullet looking device on the other side is the vent. On normal radiators you can turn them upside down and they will be closed. On that style you don’t have that option.If you truly want it “off” all the time. Put a blanket on top of the element, or something else to block the air flow, those primarily work through convection and stopping or slowing the air flow should dramatically reduce the heat output.0 -
Is the building owner aware you're working on that heater? If something breaks it can get real expensive repairing.
Too much heat just put a towel over it.0 -
If it were me I'd install a tee for a pressure gauge and a valve under that vent
Haha. Yes in your own home that would be cool but it would be a roll of the dice with boiler cycles for the OP.ethicalpaul said:If it were me I'd install a tee for a pressure gauge and a valve under that vent
I'm talking about if I were renting. But the more conservative approach would be to put a heavy blanket over it as pecmsg mentioned
Paul, not poking you in the eye, I could see that tee with gauge in your house. Mine too! Never too many controls or gauges.ethicalpaul said:I'm talking about if I were renting. But the more conservative approach would be to put a heavy blanket over it as pecmsg mentioned1
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
