Bomb proof toilet seals
woobagooba
woobagooba Member Posts: 186
Anyone have any experience with the new generation of non-wax toilet rings? Or is wax still king?
Recent spat of wax ring failures / ceiling repairs has me wondering about a better way for an underway renovation. Something durable and able to tolerate some movement of the toilet base without the seal failing. Thanks
  • ratio
    ratio Member Posts: 4,264
    I use the Korky brand of foam rings for all my (family) work. No issues that I've heard about.
    PC7060
  • jumper
    jumper Member Posts: 2,581
    Sleeve with lip and rubber seal works for me for twenty plus years. Trick is to adjust height so that bowl is really tight against rubber.
    EBEBRATT-Ed Member Posts: 20,472
    I just use one of the foam type gasket for the first time. So far so good
