How do you drain a floor standing expansion tank? AMTROL Extrol model SX30V.
vynce82
vynce82 Member Posts: 1
How do you drain a floor standing expansion tank? I have AMTROL Extrol model SX30V. I just got one installed by plumber but system pressure is high - leaking to hold at 30psi.
It is a floor standing model with copper pipping going straight up to valve near ceiling height. I can isolate with the valve but how do I drain it to test the pre-charge pressure?
    EBEBRATT-Ed Member Posts: 19,341
    There is no way to drain it. Close the isolation valve and if there is a union between the tank and the valve loosen it (there will be some pressure). No union you will have to cut the pipe and when you put is back together put in a tee with a boiler drain on it and a union in the pipe. There are no drains on those tanks as far as I know
    HVACNUT Member Posts: 7,180
    There should have been a drain installed during the installation.
    Did it change from a steel compression tank to the diagram tank? If so, is there now a means of automatic air elimination?
    If cold pressure was set to 12 psi, what happened to make the pressure rise?
    Jamie Hall Member Posts: 26,718
    It's that last question I'm wondering about. Expansion tanks don't add pressure, they just control it. How did the system pressure get that high? Bad pressure reducing/automatic feed valve? Leaking manual fill?
    mattmia2 Member Posts: 15,287
    Does it have a tankless coil or indirect water heater to make domestic hot water?
