Basic Baseray question
delcrossv
Member Posts: 2,184
In doing a hot water loop off a cast iron steam boiler (no heat exchanger) pushing cast iron Baseray convectors, shouldn't I be doing the piping in black iron? Wouldn't I get a dissimilar metals problem with copper piping in this application?
Thanks!
Thanks!
You can use a brass/bronze coupling, ball valve, etc to make the transition from black iron to copper pipe. If you are making a hot water baseboard loop off of the steam boiler I would suggest having a few isolation valves. This gives you the ability to isolate the two systems and makes a service work easier. A wye strainer from the boiler to hot water loop would also help in keeping large particles out of the baseboard. Sure it may cost a bit more upfront, but save in labor down the road.
Owner of Grunaire Climate Solutions. Check us out under the locate a contractor section. Located in Detroit area.
1 -
@offdutytech Thanks, but there's nothing wrong with doing it all in black, yes? Thanks for the strainer idea!Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
Nothing at all. I'd probably do it that way -- but I don't mind threading pipe.delcrossv said:@offdutytech Thanks, but there's nothing wrong with doing it all in black, yes? Thanks for the strainer idea!
You can certainly do it in black iron. Copper my have a bit more longevity and be easier to do if you don't have a pipe threader. Just make sure that you plan the project out and draw it before you start. It would save you some headaches as well
1 -
All below the waterline (basement loop). Thinking a B&G 100- I've had good luck with those. They do make a bronze version .EBEBRATT-Ed said:I would use copper. Especially if going above the boiler water line with no hx. Better chance of no leaks but either one is fine. You have to use a bronze pump though
- 87K THE MAIN WALL
- 57 Biomass
- 111 Chimneys & Flues
- 5.7K Gas Heating
- 106 Geothermal
- 70 Pipe Deterioration
- 978 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
