Flame opinion?
delcrossv
Member Posts: 742
I'm attaching 2 photos, one with flash, one without. Unit is a 1960's Weil McLain JB steam boiler. While I know to get something definitive you need a combustion gas analyzer, I'm looking for folks initial opinion. Flame is blue right above the burner and goes to orange the higher one gets. Air controls are almost wide open on the burners.
No black soot on the exchanger but it's all over a pale green (???)
Thanks!
Flash
No flash
Thanks!
Flash
No flash
Colored flames could be a sign of minerals (dust) in the air. Are you running a humidifier? See https://forum.heatinghelp.com/discussion/179147/dirty-gas for a similar event1
Yes, a combustion analysis is obvious. What's with the green scale?Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
It's quite dusty. No soot on the exchanger. I have to measure gas consumption vs. burner input rating first. At 660,000 BTU/Hr nameplate input, I should be using 10.637 CFM at the meter.ratio said:Colored flames could be a sign of minerals (dust) in the air. Are you running a humidifier? See https://forum.heatinghelp.com/discussion/179147/dirty-gas for a similar event
I was wondering if it was overfiring, but that would leave soot, yes?
Room CO is very low. (wall unit with ppm readout.)Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
