The boiler
maroo
maroo Member Posts: 30
edited November 2021 in Gas Heating
  • Big Ed_4
    Big Ed_4 Member Posts: 3,551
    What was written on the tag ?
    Jamie Hall Member Posts: 27,582
    Steam or hot water?
  • Zman
    Zman Member Posts: 7,614
    It sounds like you are in a multifamily building and are out of the loop on the issues with the boiler?
    If you are a member of a homeowners association, if so, the information should be a public record through the manager or meeting minutes.
    If you are renting, you might have to dig deeper. Some regions publish inspection results on state or regional boiler inspectors' website, occasionally you need to submit a freedom of information request.
    A red tag may be good news for you. Safety issues have been officially documented and the owner would be breaking the law to run the boiler without remedying the problem.
    Albert Einstein
    mattmia2 Member Posts: 17,474
    If it was done by the city, many cities have their permit and inspection documentation on line by address.
    Zman
  • maroo
    I’m not sure. It’s in the basement and I don’t want to go down there tonight but I will go look in the morning and let you know.
    EBEBRATT-Ed Member Posts: 20,481
    Could have been a gas leak and they shut the gas off. Could be a combustion issue, carbon monoxide or it could be leaking rotten boiler.
    If I were you I would get in the basement when no one is around (if you can do it legally) and take pictures of the boiler, the tag and surrounding piping.
    Either a red tag means they have to fix it or replace it a they have to provide heat.
    The owner should have dealt with this back in the summer
    maroo
  • maroo
    Zman said:
    It sounds like you are in a multifamily building and are out of the loop on the issues with the boiler? If you are a member of a homeowners association, if so, the information should be a public record through the manager or meeting minutes. If you are renting, you might have to dig deeper. Some regions publish inspection results on state or regional boiler inspectors' website, occasionally you need to submit a freedom of information request. A red tag may be good news for you. Safety issues have been officially documented and the owner would be breaking the law to run the boiler without remedying the problem.
    Yes it’s a multi family. I am afraid of who they will send to repair it because the maintenance here hasn’t done it correctly and that’s how it ended up being tagged. The last maintenance man told me about two months before when it was making weird noise that it was a pipe he said the pipe that had been on it was too small so he said he replaced it but again it still wasn’t right. I’m afraid because these people don’t know what they are doing.
    MikeG
  • maroo
    Steam or hot water?
    I don’t know. I think it’s hot water
  • Zman
    Take tons of pictures of everything from as wide an angle as you can.
    Looking at your previous posts, you seem to have safety concerns. Let us take a look at what you have.
    Albert Einstein
    maroo
