Re-filling Hydronic System
LmAcres
LmAcres Member Posts: 7
Hi Everyone
Time to refill my system after some major renovations. A coworker has said that I should close the domestic make up water valves once the system is filled and bled, but I thought they are to remain open? The (2) yellow valves are currently in the closed position in the picture, but this coworker has me questioning what I thought to be true. He's a retired homebuilder and knows his stuff, but hoping I could get a second opinion.
  • Zman
    Zman Member Posts: 7,611
    You have just tapped into a long-term debate. If you close them, what is there to prevent the boiler from running dry and melting down? Personally, unless you have a low water cutoff (I don't see one in the picture), I think you should leave them on.
    Albert Einstein
    Steve MinnichSTEVEusaPALmAcresmattmia2
  • Steve Minnich
    Steve Minnich Member Posts: 2,878
    “He knows his stuff”? That’s a recipe for disaster without a LWCO.
    Steve Minnich
    LmAcres
  • STEVEusaPA
    Before refilling you can easily put a LWCO right there.
    LmAcres
  • LmAcres
    He may assume that I have one, but I've also heard of people leaving the water open either way.
    hot_rod Member Posts: 27,354
    For about 50 years now I have been installing and leaving fill valves open.
    I suppose one flood or lawsuit could have changed my mind :)
    Another option is to use a fill tank, like an Axiom. Or a homemade fill take built with an expansion tank and prv. You want to maintain pressure on a newly filled system as it will purge air for several days or more, until multiple heating cycles drive the entrained air out of solution. A purge alone will not accomplish that.
    I third the LWC, regardless.
  • Steve Minnich
    hot_rod said:
    For about 50 years now I have been installing and leaving fill valves open. I suppose one flood or lawsuit could have changed my mind :) Another option is to use a fill tank, like an Axiom. Or a homemade fill take built with an expansion tank and prv. You want to maintain pressure on a newly filled system as it will purge air for several days or more, until multiple heating cycles drive the entrained air out of solution. A purge alone will not accomplish that. I third the LWC, regardless.
    In my experience with a properly piped boiler and a good air separator, the time needed for system air removal can happen within hours. Before people started pumping away and were still using an air scoop, sometimes forever it seemed.
    Steve Minnich
