C.I. Baseboard Section Assembly Question
ScoutRider
Member Posts: 23
So, I have been salvaging a lot (200 feet) of cast iron baseboard. Most of the ports where push nipples are installed have cleaned up just fine, but in one instance, I have a port with some very slight rust pitting. Any thoughts on how successful using a product like JB Weld might be for that particular section? I would only use it on the pitted surface where the nipple goes, and pipe dope on the other side so I can disassemble if needed.
Thanks!
Thanks!
Use RTV.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
