Insulation / Reflector Behind C. I. Baseboard
ScoutRider
Member Posts: 23
Any specific suggestion for what to use behind my cast iron baseboards? I know originally paper was used, but I'd like to know what others have used successfully here-
Thanks!
Thanks!
Eh? What is the wall finish which they are up against? Most installations one just runs the wall finish right on down to the floor -- since the baseboards take the place of the baseboard trim which might otherwise be there -- and let it go at that.Br. Jamie, osb
Do new cast iron baseboards come with reflective material at the back. We put some sort of reflective panel behind our antique CI radiators to avoid heating the external wall, but I assume they build that in these days.0
You really need a bit of an air gap for reflective foil to work properly. That is the concept behind the radiant barrier foil insulation used in attics and below radiant tube in joist bays.
If the aluminum touches the warm baseboard you would have a conduction transfer the opposite way. I think?Bob "hot rod" Rohr
Living the hydronic dream0 -
Base Ray does recommend reflective insulation behind baseray.. Mineral insulation with sheet metal over it would work if you have enough room0
- 120 Geothermal
- 394 Solar
