Help Identifying pipe type and how to connect
Candrews1992
Member Posts: 2
Hello guys! So I’ve done a bit of boilers in all sorts of applications, but I’ve run into something that has me baffled. What I’m seeing on an old house is what looks to be zinc coated steel pipe that has been directly soldered to a copper fitting - the crazy part is I saw this on two separate houses around the same time, so I’m sure there’s something I’m missing here. I’m looking to leave the house loops and reattach to this piping but with dissimilar metal concerns I’m pretty well stumped. I’ve been trying to Google this with no success, so any help would be most appreciated.
Got a picture? Can you cut, rethread and install a dialectic?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
My parent's house had the same thing, it was built in 1950. I think the tube was called Bundy tube. Their house was ahead of the time in design. The boiler system used American Standard convectors that were 10" high with a 1" diameter copper tube. They used a manifold home run system, common today, but not in 1950. The Bundy tubing was 3/8" diameter for the most part with some 1/2" diameter for some larger load areas. The tubing was imbedded in the concrete for the slab on grade lower zone and the 7" thick basement ceiling for the upper zone which was 2' above grade. In the basement above the boiler was four manifolds made from 2" black pipe with globe valves for balancing of the two pumped zones.0
The tubing was nominal copper O.D. tube diameter, and when I had to connect to it, I just sweated on copper fittings.0
I remembered this link when it was originally posted some time ago. https://forum.heatinghelp.com/discussion/comment/828244#Comment_8282440
They used to make fittings you could sweat onto a brass pipe when switching over to copper. You wouldn't be able to sweat those to steel unless you silver solder it0
I thought you could do it with the right flux. i always just filed the zinc off and used rosin flux but I was never soldering to galvanized steel for plumbing.EBEBRATT-Ed said:They used to make fittings you could sweat onto a brass pipe when switching over to copper. You wouldn't be able to sweat those to steel unless you silver solder it
According to wikipedia, bundy tubing is the standard steel tubing they use on cars and such for fuel and brake lines and it has an inner copper cladding. I suspect if you can solder to it easily that it is tin or lead plated rather than galvanized.0 -
The 3/8" and 1/2" tube I sweated to in 1996 held up fine for a couple of years when it failed elsewhere and I had to abandoned the system. The only thing I used was some emery cloth and Oatey brand flux and solder that I bought from Lowes and I used a propane torch to heat it.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 879 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
