Copper to galvanized
Alan_6
Member Posts: 87
I ran across a boiler-baseboard application today. All the baseboard and fittings are copper, all the piping appears to be a galvanized. The piping is all fitted into copper fittings, and appears to be sweated with 50/50 (lead/tin) solder. The system was installed in 1962. One of the fittings on the return manifold is leaking from the sweat joint. Would a silver bearing solder, stick to these materials, if it were clean?
piping materials
I think I've sweated copperxrheemed adapters onto galvanized nipples before.. used silver creek solder and made sure my flux worked on galvanized (Read the back)0 -
I think I've sweated copper x rheemed adapters onto galvanized nipples before.. used silver creek solder and made sure my flux worked on galvanized (Read the back)0 -
Is it Bundy tubing ?
We see that sometimes around here , mainly 3/8 rigid , home run from each radiator to the boiler . It looks like galvanized piping . If it's Bundy , it can soldered like regular copper .
Heres a pic with Bundy tube .0 -
bundy tubing
The tubing is the same size as 1/2" copper, 5/8 O.D., and is rigid like L or M copper. I scraped the tubing, it was a galvanized color, like sheet metal. Is there any stampings that identify this tubing as bundy tubing?0 -
I never looked
for stampings or lettering on Bundy tubing . I know it's very thin , like DWV copper , and I've seen it in 3/4 , 1/2 , 3/8 and 1/4 . Solder takes to the tubing just like copper .0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
