Calculating Manual Load for Heating
As I said in your other thread, don't try to use it on a smartphone. Download the program to your PC.Br. Jamie, osb
I tried using it on a Desktop computer. It froze. unfortunately isn't working.Jamie Hall said:As I said in your other thread, don't try to use it on a smartphone. Download the program to your PC.
I didn’t think the desktop one was even supported anymore?! I tried getting it a couple years ago and it didn’t work then.
The phone/tablet app works great, I just opened it again to verify and it’s all good.
1 -
To figure out the loss through a outside panel. ( Design Temp Indoor - Design Temp Outdoor) / Panel R-Value = Btu/hr Loss per sqft of outside panel. Take that and multiple by the total sqft of the panel. Make sure you take out windows, doors and plug them in separately. Then add all the losses together for the total outside panel loss. Yea, its that easy. Don't forget to calculate both ceiling and floor loss should there not be a conditioned space above or below
For infiltration factors. Per ASHREA .35 to 1. Take the cubic ft of the room x the factor. (R-19 Wall or tighter use .35, R-11 I'd use .75. Now add that to the rooms total outside panel loss and boom you have a basic launch point for the heat loss of the room. Software is great to save time but it's also carries fudge factors so they are about as accurate as doing the actual math manually. Do it both ways and let me know how far they fall apart.
This would be no different than using Longest run x 1.5 x .04 to figure circ pump foot of head for the critics out there.There was an error rendering this rich post.
1 -
I agree with that. As much as I like using the Slantfin app, it way over estimates infiltration unless you're aggressive with the numbers. The number it spits out is my max range and would try to find a unit the size below. @Crissie has the advantage of already knowing an accurate infiltration rateCMadatMe said:To figure out the loss through a outside panel. ( Design Temp Indoor - Design Temp Outdoor) / Panel R-Value = Btu/hr Loss per sqft of outside panel. Take that and multiple by the total sqft of the panel. Make sure you take out windows, doors and plug them in separately. Then add all the losses together for the total outside panel loss. Yea, its that easy. Don't forget to calculate both ceiling and floor loss should there not be a conditioned space above or below
This would be no different than using Longest run x 1.5 x .04 to figure circ pump foot of head for the critics out there.You can have it good, fast or cheap. Pick two1
- 114 Geothermal
