Climate Panel over semi-conditioned basement.
woobagooba
Member Posts: 186
I've got a Climate Panel install going into first floor whose subfloor is a patch work of old gapped boards and Advantech (air leak city). The basement below is rubble foundation with rat slab and single pane hopper windows ... semi-conditioned space, often humid in summer, dehumidifier often running, etc.
I am not ready to cross the bridge to address the basement slab and rubble walls, so I am considering treating the first floor / basement ceiling as the air/vapor/thermal "bottom" of my building envelope.
Back to the Climate Panel. I am considering placing Membrain between the subfloor and climate panel as an air/vapor barrier, then the town will require R19 batts in the floor joists below.
Does this sound like a reasonable approach?
It seems as though the subfloor would pick up the moisture, but I don't have enough experience in humid climates to say for sure.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Do NOT use any type of fibre or batt insulation below your vapour barrier in that leaky damp "basement". It will become saturated with moisture -- and critters... and bugs... and rot.
Don't ask me how I know.Br. Jamie, osb
Must ... resist ... urge ... to bust out / replace the rat slab and spray foam the basement walls!0
Consider: no rat slab, and a migration towards a new "pink heaven."
Jamie Hall speaks The Truth.
Unconditioned spaces below a living space are always problematic and require careful consideration before treatment.
Just my opinon: 'They' should stop manufacturing and selling fiberglass insulation.0 -
A complicated situation. Can styrofoam alleviate cold floors?0
