When Luck Fails You
HeatingHelp
Administrator Posts: 718
When Luck Fails You
When luck checks out, it’s time for critical thinking to check in. Go back to what you know for sure and ask that question: What changed? And then ask that second question: What can cause that to happen?
Luck is when opportunity meets readiness. Always!0
Kind of my ruling guide in troubleshooting...Br. Jamie, osb
"pretend your inside the pipe" probably the best tip I learned from @DanHolohan . I think of that one all the time0
Do what I did!
When in doubt don' run about go back to the simple book to refresh your memory. I used Dan's book (kept in my car) The Steam Book a Primer for The Non Engineer Installer.
When I went to jobs with problems I some times went looking for the big problem not all the little ones that made a system look like there was some thing big happening. This was because I was so full of myself that missed what was happening. I needed a pause in my thinking because I lost site of steam talks to you so I went to the book to ground myself and was able to do my job and correct the problems.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0
