Dwell
Intplm.
Member Posts: 3,083
What position is used when setting up the dwell period on a Mcdonnell & Miller water feeder? There are three choices? How do you figure which one is best without having to go back to the boiler at a later date?
@EBEBRATT-Ed . My thoughts as well. I have even asked ITT reps in the past. They haven't been able to offer an answer either.0
@mattmia2 . every time I turn around I have something new to learn. I like learning new things but I think what you are saying is that this setting is something you would probably have to have a "feel for"? rather than, say, strictly applying numbers to the selection? This setting on this unit, ( I haven't done a lot of them) has always left me a little puzzled.mattmia2 said:Water pressure and how fast the condensate returns in that particular system are going to be kind of hard to guess without a lot of experience.
Every system is different. Even the best of the best are kind of guesstimating... but it can't hurt to start off with a longer dwell and a shorter feed time and shorten the dwell if needed -- or lengthen the feed time. Having the boiler shut off a few extra times on low water, or staying off slightly longer, is nowhere near as messy as overfilling...Intplm. said:
Thank you @Jamie Hall and @mattmia2 Your sage advice is most welcomed.0
- 128 Chimneys & Flues
