Looking to update steam radiator in old San Franciscan building
ApartmentsSF
Hi. I have an outdated steam radiator, 1 pipe system. I want to know what the best option will be if I want to update the heating system. Will it be more cost efficient to just keep the old system or to put in a hot water radiator. Do I have other options?
Don't really understand the question. If you wan't to replace a radiator yes that can be done0
a picture showing whyknown to beat dead horses0
If your thinking about changing the radiator yes that can be done. It's likely not going to improve the efficiency at all. If your reasons are esthetic or for space/location the answer is also yes it can be done. How to go about it is another matter. More details would be in order.
Sorry all, I mean to say to replace the steam radiator with hot water radiator. Which one will be more efficient? Do I hae other options for a more efficient heating system. Thank you0
The tenants in the building wants to be able to control the heating. With the current system, they are unble to do that. In addition, the current steam radiator is very old and makes loud noises. What options do we have if we want to update the heating system?0
All the options in the world...including many bad ones
So the sounds are the result of something wrong, probably something not being installed properly when the boiler was replaced, but there are lots of other possibilities, pretty much all of which can be fixed.
Is this one pipe or 2 pipe? @ pipe is very easy to add control to, it can also be done on one pipe but is less tolerant of bad design.
It is unlikely that the slight fuel savings of another type of system would make up for the cost of replacement of all of the piping and emitters. Fixing the problems with your current system could result in significant savings.0 -
Are the apartments over or under-heated?
Who controls the heat now?—NBC0
